EDGE PRODUCTS EDG28248 COLD AIR INTAKE JAMMER FOR 2015 CHEVROLET 6.6L BALCK
Edge Jammer cold air intake kits feature a revolutionary design which improves airflow by blocking hot air and using cooler denser air for more efficient combustion. The Jammer employs a large diameter intake tube that's smoother wider and has less bends to provide uninterrupted airflow. Teamed with other Edge performance products you'll create a much more efficient system with maximum gains in power mileage and efficiency. Order the Jammer intake designed for your particular make/model and engine.
FeaturesCompatibilitySpecifications
Price: 655.90
