Introducing the all new Takeda momentum sealed intake system for the 2013 Scion FR-S H4-2.0L.
This system uses a large 360 degree high flow Pro Dry S air filter for maximum flow filtration and convenience. The Pro Dry S air filter requires no oils and cleans with simple soap and water. Also included is a wrinkle black roto-molded intake tube designed to increase airflow for maximum torque. Takeda intakes come complete with all necessary hardware. Built-in air scoop: Features a one-piece roto-molded air box that incorporates a built-in air scoop opening that captures cold air from the front of the vehicle. "Rounded nose" filter top: An aerodynamic rounded filter top is used to reduce air resistance and direct airflow smoothly into the intake track. Housing/air filter interface: This intake system features a unique patent pending filter to air box interface that creates a flawless seal. Roto-molded intake tube: A dyno tuned roto molded intake tube is used to smoothly direct the airflow into the motor with minimal restriction.
