The all new Takeda Momentum Sealed Intake System produces up to 20 HP and 18 pounds x feet of torque over stock while outflowing the factory intake by 42 percent. Unlike other Takeda intakes this system uses a Pro 5R progressive mesh five layer oiled filter for maximum airflow and convenience.
This system uses a unique roto-molded sealed airbox designed to increase airflow using the factory ram air scoop for maximum torque in all weather situations. Takeda intakes come complete with all necessary hardware. Uses factory air scoop: features a one-piece roto-molded air box that incorporates the factory front air scoop that captures cold air from the front of the vehicle. "Rounded Nose" filter top: an aerodynamic rounded filter top is used to reduce air resistance and direct airflow smoothly into the intake track. Housing/air filter interface: this intake system features a unique patent pending filter to air box interface that creates a flawless seal.
