AFE POWER AFE51-73006 MOMENTUM HD PRO 10R COLD AIR INTAKE SYSTEM FORD DIESEL TRUCKS 2017 V8-6.7L
The smooth one-piece high quality sealed housing with auxiliary air scoop is used to eliminate the use of multiple-piece housings and ensure the coolest air intake. A large clear sight window is used for a hassle-free filter inspection and an aggressive style. A urethane plug is also included if you wish to block off the auxiliary air inlet.
Features- Torque max gains plus 12 HP and plus 32 lbs. x ft. Outflows factory intake by up to 21 percent
- High Quality One-Piece Sealed Housing with Auxiliary Air Inlet
- CAD-Designed Roto-Molded Intake Tube
- Pro 10R 10-Layer Progressively Finer Cotton Gauze Oiled Media for Maximum Performance
- Unique filter-to-housing interface for easy installation
Price: 649.04
