AFE A15-TM1024BR TAKEDA STAGE 2 PRO 5R COLD AIR INTAKE SYSTEM HONDA CIVIC 2016
A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene.
Features- Torque max gains plus 13 HP And plus 13 lbs. x ft.
- Outflows factory intake by 33 percent.
- High Quality One-Piece Roto-Molded Sealed Housing with Air Inlet.
- CAD-Designed Roto-Molded Intake Tube.
- Built-In sight window provides easy inspection of filter without disassembly.
- ?Pro 5R oiled 5-Layer Progressively Finer Mesh Cotton Gauze Oiled Media for Maximum.
- Unique filter-to-housing interface for easy installation.
Price: 577.29
