AFE A15-75731121 MOMENTUM GT PRO GUARD 7 COLD AIR INTAKE SYSTEM
Our products are assured for reliability and durability which has high quality and standard. We always work towards to fulfill the requirements of our end users. Durable and reliable products at great prices You can shop for Auto Accessories suiting your budget and taste from our exclusive collection that includes top quality products to enhance the style comfort and functionality of your vehicle.
Features- +21 HP / +27 lbs. x ft. Torque max gains
- Outflows factory intake by up to 66%
- CAD-Designed Roto-Molded Intake Tube
- One-Piece Sealed Housing
- Patented Pro-GUARD 7 Media for Maximum Filtration and Engine Protection (US PAT 06811588)
- Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly
- Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation
Unique One-Piece Housing: The smooth one-piece sealed housing is used to eliminate the use of multiple-piece housings and ensure the coolest air intake charge available. A large clear sight window is used for a hassle-free filter inspection and an aggressive style- Roto-mold Tube: This System uses a CAD designed dyno-tuned roto-mold intake tube to achieve maximum power gains while maintaining a perfect fit.
- Huge 7-Layer Performance Air Filter: The Momentum GT intake is designed around a pre-oiled large 9 Tall conical inverted top 360 degree radial flow performance air filter with 5-layers of progressive cotton media with 2-layers of progressive synthetic media providing 99.7% cumulative efficiency for maximum filtration. The unique air filter to housing interface (patent pending) allows for maximum filter size which increases the available air volume while simplifying the installation process
- P
Price: 713.03
