AFE A15-5182332 STAGE-2 SI PRO DRY S COLD AIR INTAKE SYSTEM
The simple yet elegant design of the one-piece sealed housing makes installation a snap and features our patent pending filter-to-housing interface. Carbon Fiber look accent are provided for car show quality and to further distinguish your vehicle from others. A urethane plug is also included if you wish to block off the auxiliary air inlet
Features- Torque max gains plus 10 HP And plus
- Outflows factory intake by up to 29 percent
- CAD-Designed Roto-Molded Intake Tube
- High Quality One-Piece Sealed Housing featuring Carbon Fiber look accent with Auxiliary Air Scoop
- Pro DRY S oil-free 3-Layer Progressively Finer Porosity Synthetic Media for Maximum Convenience
- Unique filter-to-housing interface for easy installation
Price: 534.24
