AFE A15-5181022E DIESEL ELITE MOMENTUM HD PRO DRY S COLD AIR INTAKE SYSTEM
Our products are assured for reliability and durability which has high quality and standard. We always work towards to fulfill the requirements of our end users. Durable and reliable products at great prices You can shop for Auto Accessories suiting your budget and taste from our exclusive collection that includes top quality products to enhance the style comfort and functionality of your vehicle.
The smooth one-piece high quality sealed housing with auxiliary air scoop is used to eliminate the use of multiple-piece housings and ensure the coolest air intake charge available. A large clear sight window is used for a hassle-free filter inspection and an aggressive style. A urethane plug is also included if you wish to completely seal the airbox.
Features- +16 HP / +26 lbs. x ft. Torque max gains
- Outflows factory intake by 38%
- CAD-Designed Roto-Molded Intake Tube
- High Quality One-Piece Sealed Housing with Auxiliary Air Scoop
- Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly
- Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation
- Pro Dry S Oil-Free washable/reusable Filter For Maximum Convenience
- Washable and Reusable for Multiple Cleaning Cycles
- Includes Afe Diesel snapback Hat & 12 oz. cleaner spray for air filter cleaning
- Polyurethane coupling turbo adaptor for direct bolt-on
- No Cutting or Drilling on OEM Parts for Faster Installation
Specifications- Dimensions: 23 x 17 x 15 in.
- Weight: 15 oz
Price: 541.46
