AFE A15-5176214 MOMENTUM GT PRO 5R COLD AIR INTAKE SYSTEM
The smooth one-piece sealed housing with auxiliary air scoop is used to eliminate the use of multiple-piece housings and ensure the coolest air intake. A urethane plug is also included for those cold weather applications where you want to block the auxiliary air scoop. A large clear sight window is used for a hassle-free filter inspection and an aggressive style.
Features- Torque max gains plus 12 HP And plus
- Outflows factory intake by up to 36 percent
- CAD-Designed Roto-Molded Intake Tubes
- One-Piece Sealed Housing with Auxiliary Air Scoop
- Pro 5R oiled 5-Layer Progressively Finer Mesh Cotton Gauze Oiled Media for Maximum Performance
- Built-In sight window provides easy inspection of filter without disassembly
- Unique filter-to-housing interface for easy installation
Price: 649.04
