AFE A15-5174211 MOMENTUM GT PRO DRY S COLD AIR INTAKE SYSTEM
A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. A urethane plug is also included if you wish to completely seal the auxiliary air inlet. For Filter-to-Housing Interface.
Features- This system uses a high quality plastic CAD designed dyno-tuned roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit.
- Also included is a high quality billet aluminum crankcase fitting provided for easy installation.
- A high quality CAD air scoop guides cool ambient air to the performance air filter.
- Premium stainless steel T-bolt clamps and a silicone coupling are used for strength and durability.
- Momentum intakes are designed with fewer parts for a quick and simple installation.
Price: 649.04
