AFE A15-5174204 MOMENTUM GT PRO DRY S COLD AIR INTAKE SYSTEM
A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. A urethane plug is also included if you wish to completely seal the auxiliary air inlet.
Features- Torque max gains plus 27 HP and plus 24 lbs. x ft.
- Outflows factory intake by 19 percent
- High Quality One-Piece Roto-Molded Sealed Housing with Auxiliary Air Inlet
- CAD-Designed Roto-Molded Intake Tube with Resonance Chamber
- Built-In sight window provides easy inspection of filter without disassembly
- Pro dry s oil-free washable and reusable filter for maximum convenience
- Unique filter-to-housing interface for easy installation
- Fits models with Electric Steering
Price: 649.04
