AFE A15-5174008 MOMENTUM HD PRO DRY S COLD AIR INTAKE SYSTEM
A custom CAD designed roto-molded housing made from heat soak resistant material eliminates the use of multiple components and ensures the coolest air intake. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. A urethane plug is also included if you wish to block off the auxiliary air inlet.
Features- Torque max gains plus 15 HP and plus 37 lbs. x ft. Outflows factory intake by up to 59 percent
- CAD-Designed Roto-Molded Intake Tube
- High Quality One-Piece Sealed Housing with Auxiliary Air Inlet
- Pro DRY S oil-free 3-Layer Progressively Finer Porosity Synthetic Media for Maximum Convenience
- Built-In sight window provides easy inspection of filter without disassembly
- Unique filter-to-housing interface for easy installation
- Fits for 2017 Chevrolet Silverado 2500HD and 3500HD V8-6.6L td L5P 2017 GMC Sierra 2500HD and 3500HD V8-6.6L td L5P
Price: 652.51
