AFE A15-5173202 MOMENTUM GT PRO DRY S COLD AIR INTAKE SYSTEM FOR FORD MUSTANG
A custom CAD designed roto-molded housing made from heat resistant material eliminates the use of multiple components and ensures the coolest air intake. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene. Carbon Fiber Accent is provided for car show quality and to further distinguish your vehicle from others.
Features- Torque max gains plus 11 HP And plus 15 lbs. x ft. Outflows factory intake by 30 percent
- High Quality One-Piece Roto-Molded Sealed Housing featuring Carbon Fiber accent with Auxiliary Air Inlet
- CAD-Designed Roto-Molded Intake Tube with CNC Machined Fittings
- Built-In sight window provides easy inspection of filter without disassembly
- Pro DRY S Oil-Free washable & reusable Filter For Maximum Convenience
- Unique filter-to-housing interface for easy installation.
Price: 649.04
