AFE A15-5132413E STAGE 2 POWER DIESEL ELITE PRO DRY S COLD AIR INTAKE SYSTEM RAM 6.7L.
Our products are assured for reliability and durability which has high quality and standard. We always work towards to fulfill the requirements of our end users. Durable and reliable products at great prices You can shop for Auto Accessories suiting your budget and taste from our exclusive collection that includes top quality products to enhance the style comfort and functionality of your vehicle.
Features- Outflows factory intake by 48%
- CAD-Designed Roto-Molded Intake Tube
- Powder-Coated Top Mounted One Piece Heat Shield
- Wrinkle-Black Powder-coated aluminum cover to add a sense of style to your engine bay
- Pro Dry S Oil-Free washable/reusable Filter For Maximum Convenience
- Washable and Reusable for Multiple Cleaning Cycles
- Includes Afe Diesel snapback Hat & 12 oz. cleaner spray for air filter cleaning
- No Cutting or Drilling on OEM Parts for Faster Installation
Large 3-Layer Performance Air Filter- Large 6-1/8 tall round inverted top filter with a 5 flange opening provides greater airflow over Stock intake system. This Oil-Free 3-Layer Progressively Finer Porosity Synthetic Media air filter provides maximum Convenience With Excellent Filtration Efficiency.
High Quality Tube- This system uses a high quality plastic CAD designed dyno-tuned roto-mold intake tube to achieve maximum power gains while maintaining a perfect fit.
Top Mounted Heat Shield Design- aFe developed this heat shield to snap onto the top of the lower half of the factory air box to provide a hassle-free installation utilizing factory mounting locations.
Black Aluminum Cover- A wrinkle-black powder-coated aluminum cover is used to finish off this intake and add a sense of style to your engine bay
Price: 541.46
