This AFE Stage-2 cold air intake system produces 9hp and 10 lbs. x ft. of torque and outflows the factory intake by 20%. Enclosed in the durable 18-gauge black powder-coated heat shield; this air intake system features a washable/reusable conical air filter that improves airflow for increased horsepower and torque. This intake system also features a 3-angle adaptor and a heat-insulating polished aluminum tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. One-piece heat shield requires little or no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles. This system mounts to the factory lower intake housing.
Features
