The AFE Stage 2 cold air intake produces up to 8HP and up to 20 lbs. x ft. torque while outflowing the factory intake by up to 70%. This intake is a highly engineered heat-shielded air box with a one-piece intake tube. Handling filter duties is the PRO 5R performance air filter that features 5-layers of progressively finer mesh cotton gauze media. The PRO 5R filter is constructed with 100% polyurethane for long life and multiple cleaning cycles. The heat-insulating molded plastic intake tube is engineered for improved volumetric efficiency and maximum performance while lowering Intake Air Temps (I.A.T). Utilizing factory mounting points this system provides a hassle free installation.
Features
