This Stage-2 cold air intake system produces 18hp 14 lbs. x ft. torque and outflows the factory intake by 40%. Enclosed in a durable 18 gauge powder-coated heat shield; this air intake system features a washable/reusable conical air filter that improves airflow for increased horsepower and torque. This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. One-piece heat shield requires little or no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
Features
