This Stage 2 cold air intake system produces 12 HP and 28 lbs. x ft. of torque and outflows the factory intake by 42%. Enclosed in a durable 18 gauge powder-coated heat shield; this air intake system features a massive 6 in. base x 7 in. height filter with a 4 in. flange washable/reusable conical air filter that improves airflow for increased horsepower and torque. This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract with a built in mass air flow sensor pad that directs increased air flow with improved volumetric efficiency for maximum performance. One-piece heat shield requires little or no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
Features
