The AFE Stage 2 sealed cold air intake produces up to 28HP and up to 54 lbs. x ft. torque while out flowing the factory intake by up to 41%. Fully sealed in a durable commercial grade designed rotomolded air box this air intake system features a 5-1/2 in. PRO DRY S washable/reusable high filtration conical air filter that provides maximum filtration (99.2% efficient) and convenience (requires no oils to clean). This intake system features a heat-insulating molded plastic intake tube and a unique turbo adaptor that funnels air into the turbo for improved volumetric efficiency and maximum performance while lowering Intake Air Temps (I.A.T). The "oil-free in. PRO DRY S performance air filter is constructed with 100% polyurethane for long life and multiple cleaning cycles. Utilizing factory mounting points this system is easy to assemble and easy to install.
Features
