This awesome new Stage 2 Sealed intake produces up to 19HP and 114 lbs. x ft. torque and outflows the factory intake by up to 119%. Fully enclosed in a covered molded plastic housing; this sealed air intake system features a washable/reusable conical air filter that provides maximum convenience and easy maintenance. The housing features an attractive black diamond plate cover with a laser-cut logo name plate that provides ready access to the filter for servicing and an aggressive style. This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract all the way to the turbo and directs increased air flow with improved volumetric efficiency for maximum performance. This intake comes with the PRO DRY S performance air filter that features 3-layers of progressively finer mesh synthetic in.oil-free in. media. The PRO DRY S filter is constructed with 100% polyurethane for long life and multiple cleaning cycles. Utilizing factory mounting points this system provides a hassle free installation.
Features
