This Stage 2 cold air intake system produces 18HP and 42 lbs. x ft. torque and outflowed the factory intake by 24%. Enclosed in a durable 16 gauge powder-coated heat shield; this air intake system features a washable/reusable conical air filter that improves airflow for increased horsepower and torque. This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. One-piece heat shield requires little or no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles. The clear coat anodized top provides a great style to your engine compartment.
Features
